4eye
- SCUK Addict
![SCUK Addict SCUK Addict](./images/ranks/rank5.png)
Post
by 4eye » Tue Feb 02, 2010 9:20 am
Hi peep's... On my 410 when i pull away i get a knock...it knocks again while engine breaks or when i apply the breaks after pulling away... After the first knock of pulling away i can go up the gears fine...but when engine breaks it knocks. A while ago i broke the two(ds) transfer mounts and replaced them with solid spacer's...could this have caused or be be the cause of my problem?
I have no mechanical insight but am always willing to do it my self! Any help or pointers would be great!
![Cool 8-)](./images/smilies/icon_cool.gif)
my ride.........
![I spend far too much time on here I spend far too much time on here](./images/ranks/rank9.png)
Post
by ROBBIE » Tue Feb 02, 2010 10:45 am
sorry mate cant help with the knock
![Crying or Very Sad :cry:](./images/smilies/icon_cry.gif)
ive also developed an occasional knock on pulling away and going into second
on the tbox i replaced thy mounts with polly bushes and bolted in, the bushes give movement in all directions
- The Boss
![The Boss The Boss](./images/ranks/rank11.png)
Post
by ScottieJ » Tue Feb 02, 2010 10:47 am
Check out all bushes, mounts and UJs if a UJ has seized they can sometimes 'knock'
4eye
- SCUK Addict
Post
by 4eye » Tue Feb 02, 2010 5:01 pm
my ride.........
Angie
![Engaged 4wd low Engaged 4wd low](./images/ranks/rank2.png)
Post
by Angie » Tue Feb 02, 2010 7:48 pm
I'vw just gained a 'knock@ turned out to be UJ'S
Post
by ROBBIE » Wed Feb 03, 2010 8:59 am
on each of ya propshafts the joints that move about
![Suzuki, will you marry me? Suzuki, will you marry me?](./images/ranks/rank8.png)
Post
by Edweird » Wed Feb 03, 2010 9:19 pm
My mothers Discovery 300TDi produces a knock under braking and acceleration also.
It appears to be coming from Nearside (passenger) front suspension.
This may not help as Sj's are totally different, and if you're sure it's transmission, then this is irrelivant. However, possible check for loose bolts, bearings, perished bushes etc.
Hope this helps, though I don't know too much about Sj's, and this relates to a Disco.......I'll shut up now.
- The Boss
Post
by ScottieJ » Thu Feb 04, 2010 12:57 pm
disco could be one of the bushes on the radius arms or panhard rod bushes! or the shock tower could be loose?
4eye
- SCUK Addict
Post
by 4eye » Thu Feb 04, 2010 2:54 pm
Well i really should look at the obvious(trans mounts)...so scottie you got any rubbers layin about cheapy like!?
my ride.........
- The Boss
Post
by ScottieJ » Thu Feb 04, 2010 5:27 pm
I'vew got a box full of various bushes matey! sure i can find what you want, dont forget to check your engine mounts too, you'd be suprised as to what symptoms a broken one can give
I'm based in corsham now as well
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
