radiator problem - fan switch>?
fatdaz
Post by fatdaz » Fri Mar 28, 2014 1:13 pm
just got a new rad for my vitara td commercial, and the part where the switch screws in isnt there!
can i use some sort of universal inline switch instead?
2 samurais. 1 vit and now a vit commercial :)
Re: radiator problem - fan switch>?
Post by twiss » Fri Mar 28, 2014 2:58 pm
I used one like this... ebay special and used in combination with a relay
fatdaz
Post by fatdaz » Fri Mar 28, 2014 11:01 pm
thanks dude. why a relay?
is that the 30 quid one?
fatdaz
Post by fatdaz » Fri Mar 28, 2014 11:05 pm
i havnt measured the hoses yet but this one comes on at 90 degrees and off again at 80?
http://pages.ebay.com/link/?nav=item.vi ... 1185078563
Post by twiss » Fri Mar 28, 2014 11:40 pm
Yeah you want your temp to hover between 80 and 90 thats fine... definitely measure the pipe first
As for the relay, the temp switch will switch the relay on, and the relay switches on the fan motor.
this saves the temp switch from having all the power for the fan put though it
fatdaz
Post by fatdaz » Sat Mar 29, 2014 5:08 pm
got ya, could you recommend a relay off ebay or the like? i wouldnt know what to get lol
its a 2 wire switch.
Post by twiss » Sat Mar 29, 2014 5:40 pm
Click Here for Ebay Listing
you will need some wire, a fuse holder and a 30a fuse... and some crimp connectors (ring and spade)
For some more information on relays, read this page:
http://www.mp3car.com/the-faq-emporium/ ... it-up.html
fatdaz
Post by fatdaz » Sun Mar 30, 2014 9:31 pm
thanks dude, so at the moment is the standard fan switch in the rad taking all the power that the above relay would?
Post by twiss » Sun Mar 30, 2014 10:46 pm
not sure on the TD setup... but possibly not.
You should be able to hear it click and activate when the engine gets to about 90*C, when the fan would usually activate
fatdaz
Post by fatdaz » Mon Mar 31, 2014 9:10 pm
sorted :) all in and works as it should :D
thanks for your help :)
