Has anyone tried or know of these?
It sounds an interesting idea, simple and adjusts to suit tyre out of balance if you loose a "chunk" of tread.
Check out this link if you don't know what I'm on about.
http://www.dynabeads.co.uk/dynabeads_4x4.php
Being a tight git, I was think of using some 6mm BB gun pellets
Dyna beads tyre balancing
- Ladaman
- Suzuki Guru
Re: Dyna beads tyre balancing
I have seen videos and reports of people successfully doing this with 6mm BBs. My only concern would be the BBs wearing the tyre from the inside out. Highly unlikely I know but the inside isn't designed to withstand any kind of wear
- Ladaman
- Suzuki Guru
But won't the wear bit be the same for any media that is put inside a tyre?
Yeah. Its probably fine.
I have unbalanced 33s at the moment that don't seem to cause any bother.
