Making my Suzuki sj 410 to electronic distributer
dazerede
Post by dazerede » Sun Apr 13, 2014 9:42 pm
I have had enough of the points in the dizzy have to adjust them all the time
I have a 1.6 8v distributer and a coil is it a straight swap chears
4” calmini lift kit :)
Re: Making my Suzuki sj 410 to electronic distributer
Post by dan_2k_uk » Sun Apr 13, 2014 10:32 pm
I think a 1.3 dizzy goes straight on. Not too sure about the 1.6.
dazerede
Post by dazerede » Mon Apr 14, 2014 9:33 pm
Oh ok what is the diffrence between 1.3 and 1.6 dizzy then
Post by Darrell » Mon Apr 14, 2014 10:19 pm
I dunno :er: :er: :er: :D
Post by dan_2k_uk » Tue Apr 15, 2014 12:13 am
Mine had different wiring between the two so presumed they would be different in some other way too.
Post by ScottieJ » Tue Apr 15, 2014 8:37 am
The drive gear on the bottom of the dizzy is different I think.
That's why if using a 1.6 dizzy on a 1.3 you have to swap the housing on the back of head and vice versa.
BUT there might be a chance that the 1.6 you have has a 1.3 dizzy as people often swap it over ;)
I know a 1.3 dizzy slips straight in, the 1.6 drive gear might not quite mesh right.
For wiring follow the 1.6 into a 410 guide in the electrical section.
Also remember that there's no vac take off for the vacuum advance on the dizzy so you can't run it.
Post by ROBBIE » Tue Apr 15, 2014 9:56 am
Ive got a couple of dizzys, one has a longer shaft under the drive gear and the other has no shaft. Both came out of 1.6 vits
Post by twiss » Tue Apr 15, 2014 10:02 am
Im using a dizzy with a 1.3 gear in my 16v... can't be that different ;)
Post by ROBBIE » Tue Apr 15, 2014 10:21 am
ROBBIE wrote:Ive got a couple of dizzys, one has a longer shaft under the drive gear and the other has no shaft. Both came out of 1.6 vits
Should have finished this, only one will fit in a 1.3
Post by ScottieJ » Tue Apr 15, 2014 10:21 am
twiss wrote:Im using a dizzy with a 1.3 gear in my 16v... can't be that different ;)
yes with the correct housing for the dizzy and an adapter, it's not the teeth that are different.
