new springs :-D
new springs :-D
Got my new Springs delivered today. Cant wait to get them fitted (hopefully this weekend).
sorry for the rubbish photo will try and get a better one before I fit them.
- 2014-04-16 20.52.14.jpg (1.33 MiB) Viewed 7649 times
sj413 samurai, pro comp springs, shackles, braided hoses, 10.5x31's bumpers, buckety seats and the best mod in the world a diesel lump (vauxhall 1.5td)
- Ladaman
- Suzuki Guru
Re: new springs :-D
Nice.
Where did you get those from?
Re: new springs :-D
haha I was just typing the same thing
Re: new springs :-D
Ordered them from a company called midland road springs. They have a two inch increase in camber over standard springs and were very well priced and only took about a week from order to delivery.
Re: new springs :-D
Izuki wrote:Got my new Springs delivered today. Cant wait to get them fitted (hopefully this weekend).
You may need an angle grinder and some new bolts, so may be worth checking availability before starting the job
They are 100mm x 12mm.
Re: new springs :-D
Hopefully it won't be an issue my u bolts are in fairly good nick as I've had my axles off a few times while I've owned the truck.
Re: new springs :-D
I'm referring to the ones going through the bush, as these can often seize onto the sleeve.
You may get lucky
You may get lucky
Re: new springs :-D
It's the spring mounts. The rubber bush has a steel sleeve in it which rusts to the bolt.
Re: new springs :-D
I had the same problem with the spring mount bolts rusting together with the sleeve, right pain a I didn't have any electric where the zuk was so had to hacksaw them off, was pretty lucky with the fronts though.
Glad you didn't buy them from japanese4x4spares, they're crap :/
Will be good to see some pics when you are done
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Re: new springs :-D
So started the sj rebuild/rejuvenation today. Here's how she looked before starting.
Does anyone know a place to get reasonably priced u-bolts at short notice?
Have made spring over axle perches to weld on so i can go back to standard length shackles but keep the same amount of lift for my 31's. Also considering making front shackle reverse does anyone have any photo's of a samurai with shackle reverse kit fitted?
Picture of new rear MRS +2" spring vs old pro comp +2" rear spring. And also 2 broken u-bolts.... b*!!*cks. Think I must have cursed myself the other day d'oh.Does anyone know a place to get reasonably priced u-bolts at short notice?
