Tims SJ410 Build Project
timwilks13
SCUK Website Padawan
Re: Tims SJ410 Build Project
Post by timwilks13 » Thu Feb 27, 2014 7:20 pm
My su no longer sticks out the top of the bonnet, the bonnet just needed making a little bit taller!
Post by Edweird » Fri Feb 28, 2014 2:23 am
Wow! That's neat. Nice job.
timwilks13
Post by timwilks13 » Fri Feb 28, 2014 8:45 am
Edweird wrote:Wow! That's neat. Nice job.
partly why i photo graphed it from the back, its certainly not neat from the front!! :hahaha:
Post by ROBBIE » Fri Feb 28, 2014 10:26 am
Pics of the front needed now then ;)
timwilks13
Post by timwilks13 » Wed May 21, 2014 12:27 pm
Ok then its been ages since i update this thread, and quite a bit has gone into it since i last updated! To the point where im not sure where to even start explaining, also not sure the how the order of the images will appear so here goes.
Got some new 3" calmini springs for here, which meant extending the front hanger mounts slightly further forward as the fronts are longer than standard. This then caused my shock to foul on the bump stops at full flex, so had to cut and re-weld the shock mounts.
Going for some 31's to finished off my VL on the rear arches finally.
Also made up a couple of frames to plate the back tub off so half is solid and half is a hinged lid.
I have more pictures to add but i have just realised i dont have them all backed up on this computer. I will organise and upload the rest a bit later!
Ladaman
Post by Ladaman » Wed May 21, 2014 12:52 pm
Sweet :doublethumbs:
timwilks13
Post by timwilks13 » Wed May 21, 2014 1:19 pm
Few more pics of things. Threw some 30mm spacers on too to miss the springs on full lock, and made myself a prop spacer to stop the front prop coming out, as it was only held in by about 3mm of splines.
Found somewhere for my furry dice too.
Still need to rob a bank then can get the correct carb spring and needle, and get some extended brake lines ordered. Ill flex it up later on my test ramp and lob up a picture.
Post by ROBBIE » Wed May 21, 2014 5:03 pm
Looking good :doublethumbs:
kiwizook
Post by kiwizook » Wed May 21, 2014 8:30 pm
good work! really looks like a beast now, looks amazing
Post by Jordi » Wed May 21, 2014 9:59 pm
As said at Billing bud, looking really tidy now. As and when I've got time I'll try and get those doors to yours see if they're any good to you for half doors.
