front diff bearings
Vitara Tim
front diff bearings
Post by Vitara Tim » Wed Jun 04, 2014 7:49 pm
Hope someone can help me if possible, is there anyone in the UK that does a diff rebuild kit for vitaras
tried my local bearing suppliers but no good, found a kit from Australia and from the USA, but thought I'd check if I could get one in the UK first.
Re: front diff bearings
Post by twiss » Wed Jun 04, 2014 9:38 pm
Hi,
Im not sure on where to get an actual rebuild kit but you should bear in mind that you need special tools to rebuild a diff in order to set the backlash correctly.
Post by Darrell » Thu Jun 05, 2014 12:13 am
Just the 2 larger taper bearings are £80 each for a branded make :shock:
The kit from Auz is not much dearer than one bearing (not including P&P)
vit 3.png (132 KiB) Viewed 5717 times
Vitara Tim
Post by Vitara Tim » Thu Jun 05, 2014 7:29 pm
Hi twiss that's not a problem, I work in a HGV workshop so we've got the tools to do it,
Hi Darrell, yeah I couldn't believe the cost of the bearings as well, looks like I'll be ordering the kit from AUS. Thank you both for replying.
Post by ScottieJ » Fri Jun 06, 2014 10:01 am
95% of the time the carrier bearings are fine to re-use and you can just change the pinion bearings, crush collar and seal.
Post by twiss » Fri Jun 06, 2014 10:08 am
I've only managed to kill the side bearings in one diff so far ;)
Post by ScottieJ » Fri Jun 06, 2014 10:23 am
Well you are quite special twiss......did you run the diff dry of oil or something? Only other way they fail is being set up with too much/little preload.
Post by twiss » Fri Jun 06, 2014 5:14 pm
Pretty sure it wasn't running dry... might have been something to do with driving on fucked wheel bearings though ;)
Vitara Tim
Post by Vitara Tim » Fri Jun 06, 2014 10:52 pm
In this case all the bearings are no good, there not worn out as such, but it would of helped if the person I brought the vit off would have put the breather pipe in the axle casing and then not driving through rivers and washing the oil out and rusting the bearings, but I should have it sorted now as I've ordered a kit from the USA with everything in.
