handbrake
handbrake
hi are all handbrakes to the rear wheels on sjs rubbish, ive stripped mine oiled cables, replaced shoes, stripped & freed the adjusters adjusted them till I can barely get the drums on, and I still cant get the handbrake to hold enough to pass the dreaded mot
Re: handbrake
it depends which handbrake it is... what model and year is your SJ?
Re: handbrake
it was a 1995 samurai sport Spanish build hand brake to the rear wheels twiss
Re: handbrake
My 91 Spanish Sammy had a useless handbrake. I swapped it for a t/box one
Re: handbrake
Its always been a problem on mine... Ive had a couple of the little ratchet arms break on mine, which just lets the brakes unwind as they see fit
Always a problem child every MOT
As robbie says put a transfer box one on and get some rear discs
Re: handbrake
I used to get it to pass on the breaks and fail on hand break. Then adjust the shoes so they would bind a bit, go for retest of the hand break and it would pass. Go round the corner and wind the shoes back a bit
Re: handbrake
transfer brake now fitted & working the original brake is now in the scrap bin thank you for the help & advise
