Kiwizook's resto
kiwizook
Re: Kiwizook's resto
Post by kiwizook » Sat Jun 28, 2014 6:21 am
so after 3 days, I've managed to finish both footwells, the roof and the back of the cab, so all I have left to do is the front wheelarches, am quite happy with the results too
and I just temporarily put it back on the chassis, the new bodymounts fit, and it's a good feeling seeing it back to this stage again!
and this is the carnage I have to fix for the wheel arch, I might end up making a fibreglass wing, much easier :D
Post by donkeychomp » Sat Jun 28, 2014 10:15 pm
Tidy work matey. Surely you can weld a curved plate onto that last hole?
kiwizook
Post by kiwizook » Sun Jun 29, 2014 8:30 pm
if you look closely, you will see the outer wing also has some bodged patches on it, so I have to redo the curvy bit with the dimple in the outer wing first, and then do the actual wheel arch itself, might just make a fibreglass wing for that side, not sure yet though!
kiwizook
Post by kiwizook » Mon Jul 14, 2014 8:25 am
had the panel beater around to have a look at the repairs, and he was all happy. reason I did that, is they can require you to get a repair certificate over here, if the inspector's aren't happy at the re-vinning process. if a certified panel beater has a record, we can skip the panel and weld testing, and write out a repair cert straight away. I'm going to try and sneak it through without one though, as they are $500! so I've started sanding down the body ready to paint it when the moisture levels are down again.
also did a perk job for a mate today, and he gave me 3 goodyear wrangler radials, and 1 goodyear wrangler gs/a tyre, all in 225/75r15, on a set of escudo rims! they are the same size as the 600/16 tyres it had on it, and now I have a set of 15 inch rims, which I had wanted for a while, so I'm chuffed with that!
Post by donkeychomp » Mon Jul 14, 2014 10:30 pm
kiwizook
Post by kiwizook » Fri Aug 22, 2014 11:09 am
brand new reproduction RH samurai wing turned up, ready to be fitted to save a lot of fabrication and welding. also got the new upholstery fabric ready to be sown up, so I will have some really nice seats again too!
Post by ScottieJ » Fri Aug 22, 2014 11:26 am
Nice work! looking forward to seeing this on the road :doublethumbs: :doublethumbs: :doublethumbs:
Post by twiss » Fri Aug 22, 2014 11:42 am
Well I doubt you will ever actually SEE it on the road ;)
Post by ScottieJ » Fri Aug 22, 2014 1:34 pm
twiss wrote:Well I doubt you will ever actually SEE it on the road ;)
I will in pictures on here :thefinger:
Post by dan_2k_uk » Fri Aug 22, 2014 4:58 pm
Hadn't checked in on this build for a while. Looks like you are getting along nicely.
Keep it up and you will soon be done. :D
