Let's see your arches
I'm sorting some bits on my brothers sj and i need to find some wider arches as it's running 33s which stick out past the already quite big arch extensions, what does everyone use, I don't want to spend days fitting them just some ones that don't require much fettling and I can attach with rivnutsa mad spray them black, I found a pic on here ages ago of ones I liked but photobucket ain't working and can't find them
- donkeychomp
Re: Let's see your arches
Dans truck with "SCUK Dan2k special shit rubber" arch extentions. Just riveted on. They're 33s too.
- suzukisteve
- Suzuki Guru
mine are similar to dans. the virtual lift does take time but you end up with more room for flex.
- 20140223_141020.jpg (2.93 MiB) Viewed 7432 times
pickle power!
- d_r_1989
- Winching along now
These are mine, land rover 90 arches I believe. Easy to fit and relatively cheap. But might not be wide enough for you
- image.jpg (2.49 MiB) Viewed 7426 times
I think when I find some extra funds, I will go down the Land Rover arches route. I made a start on my SJ yesterday and will be needing new arches soon after i've welded up the small rust patches. Luckily it's quite solid and only has a few patches.
I'm not a fan of landrover arches......they look too......erm....landrover
- d_r_1989
There's nothing wrong with admitting some parts of a land rover are useful and pretty good . . . . . . . Albeit the arches are the only thing that ticks those boxes!!!ScottieJ wrote:I'm not a fan of landrover arches......they look too......erm....landrover
- donkeychomp
And I've never come across a Landrover arch waiting to be towed home...
