Welding Front Diff on an MG410
courior
Post by courior » Sun Aug 03, 2014 9:37 pm
Hi all.
I did search and read something similar but not the answer i was after :)
Q: I have manual free wheeling/locking hubs on the front axle and last time i tried a bit off road my fronts were spinning through an open diff on the slippy stuff. I wanted to buy a Spartan Locker or something similar but then i had a thought.... As i have FWH's on the front.. if i weld up the spider gears on the open diff to make it a locked diff, and use the hubs as to "select" open/locked then this should make it much better off road... I never use locked hubs/4x4 on the road (wind up etc..) so this could be good.
Thoughts?
Secondary Q: is Welding the spider gears the correct way to "weld a diff"?
Cheers,
Courior
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Re: Welding Front Diff on an MG410
Post by Jordi » Sun Aug 03, 2014 9:57 pm
My opinion is, no, no, no. Been discussed several times on here and it's just a bad idea.
timwilks13
SCUK Website Padawan
Post by timwilks13 » Sun Aug 03, 2014 10:09 pm
Even off road it would only help you out a small handful of times, for the other 98% of the time off road you just wouldn't be able to steer, some sort of locker is really the only way to go. I asked this exact question just over a year ago and very glad I didn't go ahead.
courior
Post by courior » Sun Aug 03, 2014 10:58 pm
Thanks for the comments lads... So i suppose the downside would be that the steering would be compromised, but i dont see how?.. I understand this when talking about on road.. but off road in mud/gravel/slippy stuff.. Or even climbing a rock when 1 wheel is in the air i would of thought that it would be very helpful and more than 2% of the time (loads of youtube off road vids show a car climbing then when the front open diff spins a wheel they get stuck).. I did a small little off road rock/gravel obstacle and having the front locked somehow would of really helped....
How would a welded diff effect steering off road? i would of thought a lock right/spartan locker would still keep things locked as they are stronger than the tyres grip on sloppy mud/gravel?
Remember i would not EVER drive on a road with the hubs locked. so this is purely for use off road.
Not wanting to start a debate/argument... Just want to understand fully why this is not a good idea.:)
Cheers.
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Post by twiss » Mon Aug 04, 2014 9:14 am
If you weld the diff steering off road in 4wd will become almost impossible
courior
Post by courior » Mon Aug 04, 2014 9:44 am
Ok thats short and too the point..... So.......... Whats the cheapest locker?? I think Spartan lockers are good, but i cant see them for a 410, only a 413.
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Post by twiss » Mon Aug 04, 2014 9:52 am
To be honest I'm not sure if you can get 410 front lockers...
You would probably get better off road performance from a powertrax locker (similar to spartan) in the back, rather than a locker in the front.
The front wheels have the weight of the engine over them anyway so get quite a bit of grip, whereas there isn't that much weight over the back wheels so they spin up really easily.
You can get the rears from Jimnybits but they are almost £350...
The other thing is, it might be worth seeing if you can get a chinasoong (chinese) air locker for the 410.
The powertrax is massively expensive and I think the chinese air lockers (comes with a compressor) aren't a huge amount more than that!
Personally I would get some A/T or M/T tyres first as you will get a hell of a lot more grip just from that
courior
Post by courior » Mon Aug 04, 2014 1:11 pm
Yeah. Currently have chunky road tyres on it. Very good at light rock crawling so far. But its bone dry here. Once it gets wet I think I'm going to struggle. Better tyres it is then !
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
Post by twiss » Mon Aug 04, 2014 1:23 pm
Im not bringing any tyres over with me in september haha
We will have to find out exactly what your road-tyred gypsy can do ;)
courior
Post by courior » Mon Aug 04, 2014 1:32 pm
It will be much better with a decent carb on it! And some bushes in the suspension! Its metal on metal now.
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
