SU carb question
Lash151
SU carb question
Post by Lash151 » Mon Aug 18, 2014 9:02 am
Hi... Quick question... If I fit an SU carb in my SJ410... Do I use the standard air box with it?
Cheers Lee
Re: SU carb question
Post by twiss » Mon Aug 18, 2014 9:13 am
Hi Lee,
Haven't done is myself but I believe you can....
There is a guide with some (small) pictures here
http://www.suzukiclubuk.co.uk/diy/15-en ... 10-su-carb
Lash151
Post by Lash151 » Mon Aug 18, 2014 9:19 am
Nice one... thank you! I shall check that out. I have been looking for an air box, but I am thinking I should go for an SU if I am messing about with it.
Post by twiss » Mon Aug 18, 2014 9:23 am
tbh the main improvement of the SU is that the HIF44 is much more reliable than the carb fitted to 1.3 SJs.
As the 410 carb is working I might save myself the hassle and keep it, they are pretty good carbs anyway
Lash151
Post by Lash151 » Mon Aug 18, 2014 9:28 am
twiss wrote:tbh the main improvement of the SU is that the HIF44 is much more reliable than the carb fitted to 1.3 SJs.
Yes, it's working fine... Maybe i will just fit an air box for now.... and see how it is
Pugsley
Post by Pugsley » Mon Aug 18, 2014 11:31 pm
Think you will find that the HIF 44 is too much for a 410 - when I had mine I used a HIF 38 with the standard air box.
Lash151
Post by Lash151 » Tue Aug 19, 2014 12:28 am
Pugsley wrote:Think you will find that the HIF 44 is too much for a 410 - when I had mine I used a HIF 38 with the standard air box.
I think Twiss meant HIF 38... Did it make a big difference? The stock carb is working fine at the moment, is it worth changing to an SU?
Post by dan_2k_uk » Tue Aug 19, 2014 7:01 am
I think I just replied to you on Facebook too.
don't bother changing a stock 410 carb if it is working. they are brilliant little carbs.
Post by twiss » Tue Aug 19, 2014 9:10 am
Yeah I only mentioned the HIF44 in relation to the 1.3 engine
HIF38 is definitely the correct one for the 1.0, but as me and dan have said, not really necessary unless your carb is broken!
As some indicator of how good 410 carbs are... we pulled a 410 out of a barn... hadn't moved for 10 years
It was so bad that the throttle disc was completely jammed solid, about half an hour with the carb cleaner and it was going perfectly again!
Lash151
Post by Lash151 » Tue Aug 19, 2014 6:12 pm
That's cool... I will stick with the original carb and put and air box on.
