need abit of help
need abit of help
my stalks flop around like crazy in the steering column casings am i missing something they secure too? pic of casings below show some holes that i have nothing for the 3 in triangle formation
- 2014-08-20 14.36.37.jpg (2.63 MiB) Viewed 8413 times
- 2014-08-20 13.02.18.jpg (2.42 MiB) Viewed 8413 times
Re: need abit of help
I've no idea but to help someone who may are they round or square stalks?
round stalks bud
Not sure about the plastic casing but I think 4 screws hold the switch assembly to the steering column.
- Suzuki SJ switches.jpg (94.52 KiB) Viewed 8363 times
i must be missing something off column then to screw it too anyone have a pic of what stalks screw too?
Now I'm a bit confused because this pic shows screws top and bottom and the column bracket looks correct for this..
- switches.png (278.62 KiB) Viewed 8336 times
none of those brackets on my column
previous owner must of bust them off when bust ignition barrell off damn
Doesn't this depend on your sj year/model etc? Just had to get inside mine due to lighting fault - the covers (you show) are not the mount for switches on mine they just cover all the gubbins, and are fixed together with 3 small cross-head bolts (about M4 maybe, guess) into the 3 holes nearer centre of moulding, and then 2 long self-tappers into holes at front. The first 3 fix lower moulding to metal on column but do not fix the switches. On mine (a '91, spaniard) the switch blocks are seperate (left and right) and each is fixed to the bracket on column using 2 more cross-head bolts (about M4 again, guess) - these go through the plate on column into blind threaded holes in switch block.
Sounds to me you are missing a few screws but yours may be the different version anyway - all switching on one lump like Darrell's pic??
p.s. if yours sounds like mine (i.e. seperate switch blocks left and right) I can do a pic as it's still in bits
Douglas
Douglas
my switches are one lump so looks like i need a upper steering column good old p/o bodgedjc wrote:Doesn't this depend on your sj year/model etc? Just had to get inside mine due to lighting fault - the covers (you show) are not the mount for switches on mine they just cover all the gubbins, and are fixed together with 3 small cross-head bolts (about M4 maybe, guess) into the 3 holes nearer centre of moulding, and then 2 long self-tappers into holes at front. The first 3 fix lower moulding to metal on column but do not fix the switches. On mine (a '91, spaniard) the switch blocks are seperate (left and right) and each is fixed to the bracket on column using 2 more cross-head bolts (about M4 again, guess) - these go through the plate on column into blind threaded holes in switch block.
