MG410 Vacuum Advance
courior
Post by courior » Sun Aug 31, 2014 1:05 pm
Hi all,
I know my vac adv is not holding pressure as when i suck the pipe, although the advance WORKS and moves inside the dizzy, i am constantly pulling air (will mean a vac leak in the motor as well then). So more than likely there is a pinhole in the diaphragm in the advance. Is there anyway to repair these? The unit looks sealed so i dont think i will be opening it up, but i was thinking maybe to poor some of that poundland style super glue down the vac take off pipe and shake it about in the hope that a drop of it goes over the pin hole and then blow down the vac line to force a bit of glue through the hole and then when it dries hole should be filled? Good idea? or waste of time?
Cheers!
Courior
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
Re: MG410 Vacuum Advance
Post by twiss » Sun Aug 31, 2014 2:54 pm
It might work I suppose!
I don't think the vac advance is under that much suction, but all the same i would probably leave it a good while to dry! Won't take long in the maltese sun ;)
Post by Darrell » Sun Aug 31, 2014 4:31 pm
I'd be tempted to leave it alone. As long as the advance works.
If the glue buggers it up in any way your stuffed without the option of a new one.
I can't see a very small hole allowing enough air through to run lean.
Post by twiss » Sun Aug 31, 2014 5:08 pm
Yeah tbh you get most of the advance mechanically anyway... I don't run vac advance on mine and its works pretty well
courior
Post by courior » Sun Aug 31, 2014 6:35 pm
Cheers lads. I might just block it off then and see if it makes a diff. If not I'll leave it like that.
Maruti Gypsy MG410
5 speed box
1.5" Shackle Lift
Daymaker led lights
