bikini top
Re: bikini top
Post by Tramp » Sun Aug 24, 2014 10:58 am
Re: bikini top
Post by ROBBIE » Sun Aug 24, 2014 1:57 pm
Tramp wrote:What about these?
http://www.ebay.de/itm/251350743687
Some other cool stuff on there as well
Click Here for Ebay Listing
djc
Re: bikini top
Post by djc » Sun Aug 24, 2014 8:26 pm
Yes, that German supplier looks interesting, will need t o translate some of it, I suspect quality is good. The bikini top has that flap behind - looks a bit er... ladylike :D
Douglas
djc
Re: bikini top
Post by djc » Sun Aug 24, 2014 8:53 pm
88SJ wrote:You say your hood is tight on rear poppers....do you have and use the straps that go from rear top corner of hood hoop to rings on rear of anus?? This should mean the poppers are not under toooo much stress...
Don't seem to have straps like that but found there are 5 tabs with poppers that fix onto steel support (along back edge above rear window) - fixed those and it helps a lot, can pull the support rail downwards when fixing bottom poppers and clips. Just need to replace one fixing now (previous owner mashed) and otherwise it's good. Thanks for the tip, i had totally missed those fixings.
Douglas
88SJ
Re: bikini top
Post by 88SJ » Mon Aug 25, 2014 11:17 am
Just to confirm pal...these straps
djc
Re: bikini top
Post by djc » Mon Aug 25, 2014 3:17 pm
Don't have those straps 88. Wondered what those loops on body were for - may also be to hold frame down when hood is off? I assume that is the Monsoon? With those top poppers done on mine it's pretty close now. I will try and replace the damaged corner one and give it a clean. Too many other bits to spend on at the moment!
Douglas
djc
Re: bikini top
Post by djc » Tue Aug 26, 2014 7:08 am
Found Bestop Uk, surprisingly <bestop.co.uk>, they are indeed Derby. I'll get in touch re their bikini tops.
mail is: info@travall.co.uk. Phone 01332 387630.
Douglas
djc
Re: bikini top
Post by djc » Mon Sep 29, 2014 6:59 am
Just seen a weather forecast... rain??! Scottie, I might be needing your black bikini, pm sent. [It's OK, my wife doesn't read this forum.]
Douglas
