own loom
- urbanzook
- Winching along now
own loom
has any one made there own loom?
mine has bin wrecked by last owners an the puddels i like going in.
i wanna make a walter tight loom with a good earth an good wireing.
wots the min wireing i need. lights horn wipers heater dash engine live starter alto.
Re: own loom
I think the wiring on the SJ is quite basic as it is, you have no ECU to contend with, so it is just your lights (side, main, flasher, stop, tail, reg iluminator) horn, wash/wiper for the legal side of things, altanator is a must then heater, stereo just to make things abit more comfy, and fuel gage is always helpful! and if you want youd dash to light up
Dan
Dan
Re: own loom
an idea?
put all wiring into silicone tubing?
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
- urbanzook
Re: own loom
good thinking zook
Re: own loom
Would keep it dry and out of the dirt!
I dont know who, when or on what forum but they had a rear prop break whilst driving, the loom runs under the body along the drive train tunnel, when there prop went bang it took out the loom, leaving them with no rear lights on a very dark night, may be advised to reroute it inside, although that means cutting or finding holes, or along the chassis like the fuel and brake lines.
Dan
Dan
- urbanzook
Re: own loom
i saw that post 2 iv all ready got a plan for that.
trailor cabel running inside the body down the driver side seal in 2 my tail gate where my new trailor bored lights will be.
as iv planed for a solid rear bumper my lights need to be moved.
- Tramp
Re: own loom
look, do away with the lights and get a daylight mot, remve the indicators, if they arent fitted you dont need them, fold your wind screen down and the wipers are untestable (as are the screen wash) tada all sorted, the only thing you need is a visable brake light im sure you could make that single cable completely water tight
- urbanzook
Re: own loom
yer but id be well f##k when i go out off a night wich i do a lot coz is much more fun when ya cant see. also my anus is in daly use as i work on bilding sites an my astra is way 2 low i have problems when theres leves on the road, lol
- 1.jpg (55.51 KiB) Viewed 8861 times
Re: own loom
Tramp wrote:look, do away with the lights and get a daylight mot, remve the indicators, if they arent fitted you dont need them, fold your wind screen down and the wipers are untestable (as are the screen wash) tada all sorted, the only thing you need is a visable brake light im sure you could make that single cable completely water tight
All cars used in the UK have to by law have at least 2 front and 2 rear lights, wipers and washers.
My car failed the MOT because i forgot to put the water pipe into the the new washers!!!!
