SJ410/413 front wings
Can anyone confirm if 410 and 413 front wings are identical and interchangeable? I have a 1989 410 and from images on-line, looks like both 410 and 413 are the same profile with same fittings?
Re: SJ410/413 front wings
IIRC they are the same, samurai ones are different...
i think 413s still have the side repeaters mounted at the front, if not there will be an extra indicator hole!
Different lips on the Samurai wings too to take the bigger arch extentions.
All wings are interchangeable.
410/413 have a large indicator lense at the front. Samurais have a badge fitted there and a smaller indicator fitted further back.
The plates that the lights and grill mount to are also different and need modifying if you want to fit a 410 grill on 413/samurai wings and vice versa.Jordi wrote:Different lips on the Samurai wings too to take the bigger arch extentions.
I got a brand new samurai wing to fit on my sj410, and found out what scottie said. I just drilled out the spot welds on the headlight mounts on both my old and new wings, and changed them over
Many thanks - have managed to find 2 new 'old stock' wings
where from? did they have any more?bramley wrote:Many thanks - have managed to find 2 new 'old stock' wings
