Headlight glass
Vitara Tim
Headlight glass
Post by Vitara Tim » Sun Nov 09, 2014 12:16 am
Hi to everyone, this may be a silly question, but can you remove the glass on vitara headlights. As mine have filled with dirt and its now making the headlights dim. I did remove the clips and the glass didn't come off. Is it bounded on or just stuck with dirt. Hope someone can answer this question for me. If it doesn't come off looks like I'll need a pair of headlights. My Vitara is a 1996 SWB if that helps.
Re: Headlight glass
Post by donkeychomp » Sun Nov 09, 2014 12:52 am
Fraid not they are sealed on. I have some spares if you need one.
Re: Headlight glass
Post by Darrell » Sun Nov 09, 2014 11:20 am
Can you not just take them off and remove the bulb and wash them :er:
Re: Headlight glass
Post by dan_2k_uk » Sun Nov 09, 2014 1:46 pm
I would just fill it with detergent and warm water and let it soak a while. Then shake it all about to get and loose muck off. Then get a rag on the end of something pokey in there.
Vitara Tim
Re: Headlight glass
Post by Vitara Tim » Mon Nov 10, 2014 8:50 pm
Thank you all for the replies, just as I thought then they are sealed on. Someone at my work said about washing them out, so ill give that a go first and see if that helps. Thanks donkeychomp if I need one I'll let you know.
Re: Headlight glass
Post by donkeychomp » Mon Nov 10, 2014 10:02 pm
No worries, washing them should work fine.
