handbrake cable
bourneyo
handbrake cable
Post by bourneyo » Tue Apr 22, 2008 11:23 pm
Right folks, i got round to doing my handbrake today, I have put a 410 t-box and transmission brake on a samurai, i have got the correct cable and the correct leaver. my problem is, were do i secure the cables outer casing to? when i pull the leaver the whole lot moves so surly the casing needs securing down to create the tension!
Dan
pepe-le-pieu
Re: handbrake cable
Post by pepe-le-pieu » Wed Apr 23, 2008 11:33 pm
HI Dan,
when I modified th sj into the blitz i ha dto change the fixing of the cable too. and i have a tb from a 410 as well.
so above the transfer box there is a cross member. if you put your brakecable along it starting at the hand brake the nuts are going to be near that cross member. you just have to get a L shaped plate, bolt it on the cross member and attach the cable to it.
I get some pics for you in the mean time i made a wee drawing if it canhelp :roll: :roll: :roll:
yes yes i bought it to save the rhino...long time ago
pepe-le-pieu
Re: handbrake cable
Post by pepe-le-pieu » Sat Apr 26, 2008 12:41 pm
here are the pics of the bracket. you will see on the 2nd pic where the old hand brake cable mounting was. hopeit helpsImage
bourneyo
Re: handbrake cable
Post by bourneyo » Sat Apr 26, 2008 2:26 pm
cheers pepe thats a grate help!
just gota find time to do it now, and the HUGE amount of welding on the rear arches! :shock:
Dan 8-)
zook
Re: handbrake cable
Post by zook » Wed May 14, 2008 5:12 pm
that is a great help 8-) as i is to doing this i have looked at it and tryed to find away with out doing a bracket but its no good
going to have to make a bracket like that
cheers karl
urbanzook
Re: handbrake cable
Post by urbanzook » Tue Jul 08, 2008 9:21 pm
HAY THINK OUT SIDE THE BOX MOVE THE HAND LEVER DRILL 4 NEW HOLES AND BOLT DOWN 10MIN JOB! AND THE HAND BRAKE LEVER IS DIF 2 I USED THE ONE FROM THE DONER WHERE I GOT THE T BOX FROM
