Page 2 of 2
Re: Clutch
Posted: Sun Mar 16, 2014 2:02 pm
by TomBod08
Wow thanks for all the replys guys. It sounds easier than I thought and cheaper too.
Re: Clutch
Posted: Sun Mar 16, 2014 5:55 pm
Hardest bit is probably aligning the clutch but even that's not hard.
I would recommend buying a clutch alignment tool though, they are cheap and save messing around lining the clutch up by eye.
Re: Clutch
Posted: Mon Mar 17, 2014 9:38 am
It depends on the tool really... I've got one of the Draper blue plastic ones and I find it easier by eye than using the tool!
Re: Clutch
Posted: Mon Mar 17, 2014 11:12 am
twiss wrote:It depends on the tool really... I've got one of the Draper blue plastic ones and I find it easier by eye than using the tool!
Or it could just be the person using it
Re: Clutch
Posted: Mon Mar 17, 2014 12:12 pm
nah they are shit you want the metal ones that have all different attachments...
or the first motion shaft out of an old gearbox
the alignment tools that come with the XTD clutches look quite good. I'd be tempted to get an XTD next time I need a clutch mostly for that tool haha
Re: Clutch
Posted: Mon Mar 17, 2014 12:51 pm
You mean these ones?
- image.jpg (18.25 KiB) Viewed 4802 times
I think it's you twiss, they are easy to use
What do they say?...........
A poor workman blames his tools
Re: Clutch
Posted: Mon Mar 17, 2014 1:04 pm
Yeah I've got one of those ones, after I used it a few times the plastic end that fits in the clutch plate center hole have gone too flexible and it stopped doing up tight enough, so the clutch plate wobbles around a bit
the other thing is, with my weird gearbox not coming out issue (I have to take the rad off and tilt the engine forwards) the blue draper one wont fit in the bell housing... so I have to take the rad off to change the clutch!
first motion shaft is the best as its only about 3" long
wish I'd spent £15 on a metal one instead of £9 for a plastic one in the first place! never mind
Re: Clutch
Posted: Mon Mar 17, 2014 8:28 pm
by Pugsley
I would recommend that you drain the gearbox oil as the first job. Sometimes things don't entirely according to plan and you may find yourself putting the gearbox at severe angles whilst trying to remove it or getting it back in. The last thing you want is oil dripping about on your new clutch. Just refill it back through the gearlever hole when you are ready.
