Looks like it may have been driven through salt water or something like that with all the rust on the suspension part,could well be wrong but hope you get it all sorted out quickly.
Cannot help you with the brake or suspension problems a rebuild kit could bring back the calipers like new again.
hi, and help
- RickUK
- Can I have a tow
Re: hi, and help
Deceased.
Current wheels.
Current wheels.
- plugspanner
Re: hi, and help
my bleed nipple and metal pipe to calliper were also badly corroded, so changing it for the mot was essential.
I just chopped the old metal pipe off, took the calliper to the workshop and used some stillsons to get the bleed nipp0le out as it was rounded anyway.
I made a new pipe and got some bleed nipples from ebay:-
http://www.ebay.co.uk/itm/131042379228
these have bigger heads than the old ones making getting them off again much easier!
my vitara seem to be more rustier on the rhs for some reason, I also only recently chucked out the old suspension inc both front 'A' arms.
good luck.
good luck.
Re: hi, and help
That's a common uk phenomenon, some previous owner will have kept it on the side of a busy road, in the winter the road will have been gritted and passing traffic will have thrown it up the rhs of your truck causing it to corrode more, well that's what it usually is!
Re: hi, and help
See a lot of motors rusted at one end badly like that, used for launching and brining boats out of the water
Re: hi, and help
fortunately this ones only bad at front rears not bad at all aside from the usual rear seatbelt mounts! which im doing at the moment, know a diver who had a fourtrak that practically didn't have a floor in the back! growing up in the islands I know rust intimately! check my old series hopefully once I get it sorted it will last me a good while had a bit of a run of bad luck with motors
that would be cool if you have anything fire us a PM cheersAnton wrote:I may have a set of Vitara calipers I rebuilt a while ago. I can't remember if I rebuilt them, or just bought the parts - I've rebuilt about 4 sets, and ended up only using the standard SJ ones front, Rover 200's rear.
I could dig through and see what I've got if you'd like?
- 100_1185.JPG (798.17 KiB) Viewed 3588 times
