What about these?
http://www.ebay.de/itm/251350743687
bikini top
Re: bikini top
Re: bikini top
Yes, that German supplier looks interesting, will need t o translate some of it, I suspect quality is good. The bikini top has that flap behind - looks a bit er... ladylike
Douglas
Douglas
Re: bikini top
Don't seem to have straps like that but found there are 5 tabs with poppers that fix onto steel support (along back edge above rear window) - fixed those and it helps a lot, can pull the support rail downwards when fixing bottom poppers and clips. Just need to replace one fixing now (previous owner mashed) and otherwise it's good. Thanks for the tip, i had totally missed those fixings.88SJ wrote:You say your hood is tight on rear poppers....do you have and use the straps that go from rear top corner of hood hoop to rings on rear of anus?? This should mean the poppers are not under toooo much stress...
Douglas
Douglas
Re: bikini top
Just to confirm pal...these strapsdjc wrote:Don't seem to have straps like that but found there are 5 tabs with poppers that fix onto steel support (along back edge above rear window) - fixed those and it helps a lot, can pull the support rail downwards when fixing bottom poppers and clips. Just need to replace one fixing now (previous owner mashed) and otherwise it's good. Thanks for the tip, i had totally missed those fixings.88SJ wrote:You say your hood is tight on rear poppers....do you have and use the straps that go from rear top corner of hood hoop to rings on rear of anus?? This should mean the poppers are not under toooo much stress...
- IMG_0181.JPG (2.7 MiB) Viewed 5453 times
Re: bikini top
Don't have those straps 88. Wondered what those loops on body were for - may also be to hold frame down when hood is off? I assume that is the Monsoon? With those top poppers done on mine it's pretty close now. I will try and replace the damaged corner one and give it a clean. Too many other bits to spend on at the moment!
Douglas
Douglas
Re: bikini top
Found Bestop Uk, surprisingly <bestop.co.uk>, they are indeed Derby. I'll get in touch re their bikini tops.
mail is: info@travall.co.uk. Phone 01332 387630.
Douglas
Douglas
Re: bikini top
Just seen a weather forecast... rain??! Scottie, I might be needing your black bikini, pm sent. [It's OK, my wife doesn't read this forum.]
Douglas
Douglas
