wheel bearing
Re: wheel bearing
Post by Darrell » Thu Sep 04, 2014 12:08 am
Further investigation and the vitara bearing is the same bore and diameter as an SJ bearing.
Even the Vitara bearing is twice the width of an SJ one.
It just has a one piece outer race. So I assume the inner race is the same for both ??
So we will see ;)
Untitled - 4.png (652.75 KiB) Viewed 2417 times
Re: wheel bearing
Post by Darrell » Thu Sep 04, 2014 12:12 am
Can I go to sleep now :D
"O" Sod, I haven't even had a bath yet.
I've been searching for hours...........
Sad git !!
Re: wheel bearing
Post by donkeychomp » Thu Sep 04, 2014 10:09 pm
Cheers Darrell but it's sorted now. Previous owner bodged in SJ bearings into a Vitara sleeve...got the correct Vit bearings on now. You can sleep soundly now!
