Fwb's SJ410 Build
Re: Hello from far far far away
Hi there from Lincolnshire....Don`t know a thing about shackles but a big welcome to you
`The reason a dog has so many friends is that he wags his tail instead of his tongue` ....Anon.
Tim, If you come back over here, mu rig will probably be finished by then, and you should definitely come over to have a look mate!
if I'm ever over in parmy again, I mighty come have a look at yours too fwb2700
- donkeychomp
timwilks13 wrote:What dan said ^^^
Im from Napier originally, but moved to the UK years and years back, now living in poland with my canadian lass and we're looking to head back over to NZ in the next year or two so if you're still rocking the SJ's i'll have to pop for a gander!
Another SCUK member with a Canadian girlfriend! Oh and welcome!
- Fwb2700
Well I have been thinking a bit more. Semi decided that doing a half arse job on a lift is probably not a good idea. My front leafs are pretty much unusable anyway since they are inverted and the shocks are stuffed aswell.
I am wanting to do the rear disk break conversion so I am trying to find a spare front diff and hopefully leafs and shocks also. Hoping someone has for a hilux diff swap around here.
Then I can just keep the Zuk at standard height and will be trimming guards anyway due to rust.
What size tyres can I go up to without losing what little power the 1ltr has? Also if I go too big will it damage axles etc? I think I have the transfer box everyone seems to want but I am unsure how do I tell. It has the hand break drum break on it
1984 Suzuki SJ410q Winch Truck (Work in Progress)
- timwilks13
- SCUK Website Padawan
I ran 31's on my 410 with standard axles etc, but i did drop a 1.6 in for that extra grunt. But the axles etc held up just fine, advantage of 410 axles is they have smaller diffs so better ground clearance. If it hasnt been changed you will have a 410 transfer box, which is the one people with 413's put in.
- Fwb2700
It is defiantly all standard even the bearings and seals were original or genuine replacements. Fixed them all apart for one wheel bearing I am waiting on.
Hopefully I can find a front diff. Is there many differences in the 413? If I get one of those can I use the cvs as spare? Or is only the suspension and breaks useful?
Looking forward to the build!
The 413 (not samurai) shafts and CVs fit the 410 axles but the diffs don't, have a read of the axle info thread in the transmission section and it tells you all the differences and what parts can be swapped between axles etc.
- Fwb2700
I will go find it now then thanks heaps for the advice so far. I am looking forward to being able to drive it offroad for the first time since it was basically I drivable when I got it
- Fwb2700
Fully stripped back and painted the chassis tonight. Got 2 coats on apart from the area yet to be welded. Looks so nice and shiney.
Got the handbrake on transfer apart and cleaned the transfer, have rebuilt front diff just need to rebuild calipers and put wheels on.
While cleaning hubs unfortunately found one completely stuffed. Broken springs inside
Re: Fwb's SJ410 Build
If you are cutting the arches anyway due to rust then do a Virtual lift. By far the best way to fit bigger tyres without raising the center of gravity.
There is a little guide I wrote here.
http://forum.suzukiclubuk.co.uk/vi ... =10&t=8046
Will allow you to squeeze 31s on at standard height.
