Will this engine fit??
- Fwb2700
Re: Will this engine fit??
Now that sounds tempting. My f10a still runs and was ok for the few mins it was running
1984 Suzuki SJ410q Winch Truck (Work in Progress)
I'll buy your f10a if you remove it.
I looked at some g16 motors, but they are really pricey around here, you might pick up one cheap if you're lucky though
- Fwb2700
Is your engine not running?
my engine is running sweet as mate, I fully rebuild it, apart from the main bearings, which were reasonably new and in good shape anyway. I swapped the head and fully rebuild it, all new gaskets, honed the cylinder bores etc, and also converted it to a su hs2 carb, which makes it really nippy. I just like to have plenty of spares for everything, especially things like starter motor's, alternators, manifolds etc. give me a bell if you're around here, and I can show you mate!
- Fwb2700
Might be over that way round the Xmas New Years break. By any chance have you got any front leafs not completely flat lying around? Mine are inverted slightly
