putting the lights on make the engine rev ?????
clark
Re: putting the lights on make the engine rev ?????
Post by clark » Sun Jan 25, 2015 7:10 pm
Right then , that's sorted the idle speed surging when I draw power , but now it wont idle at all , is there a way of setting the idle speed on tick over like the old carbs ???
Post by ScottieJ » Sun Jan 25, 2015 7:16 pm
Yes there is an idle adjustment screw, Darrell's prob got a pic but it's a long screw that pokes diagonally up you can see if looking down at the carb between the rocker cover and carb plenum.
clark
Post by clark » Sun Jan 25, 2015 7:18 pm
thanks for the info scottie , I was panicking about trying to find a new carb
Post by Darrell » Sun Jan 25, 2015 7:29 pm
It's been a long time since I've adjusted mine, think it's this one.. :er:
clark
Post by clark » Sun Jan 25, 2015 7:34 pm
Thank you Darrell and scottie , ive disconnected the idle plug and adjusted the idle screw , shes now running sweet as a nut , I shall give her a good blow tomorrow and see if shes ok , ive only just had it and its been standing for 12 mnths , 62 k genuine miles , I gather quite a find , just wanted something for shooting and stumbled across it , its completley original .
Post by ROBBIE » Sun Jan 25, 2015 10:07 pm
ScottieJ wrote:
That's about the dim dip relay not the idle up system ;)
Yeah your right :oops: forgot about that, was so long ago that it was disconnected
Post by ScottieJ » Sun Jan 25, 2015 11:40 pm
No worries robbie :doublethumbs:
Sounds like a good motor.
You should start a thread on it so we can see some pics :doublethumbs:
Post by ROBBIE » Mon Jan 26, 2015 8:39 am
Quick stupid question, would it be worth putting a switch in so the idle up can be turned on and off? Would be like disconnecting when the lights are switched on and then reconnecting when lights are off.
Post by ScottieJ » Mon Jan 26, 2015 8:55 am
Most people loose the system when they swap carbs anyway, but if running a standard carb it wouldn't be hard to put it on a switch. However is it really needed? Most people seem to have no issues without it.
Post by ROBBIE » Mon Jan 26, 2015 9:04 am
Only asked when I remembered that when I got my last one it was switched, took months to work out what the switch was
