I bought a refurbished one from a totalled Suzuki, and it is a Denso with the same reference. It seems to be working (as far as resistances are correct, because my engine is still open).
My mechanic also told me that ALL valves were leaking. What could have make that happen on a 50K km engine? The engine itself did not seem to have been opened before, although admission was glued back with silicon paste.... sorry if that is not the correct name, not something I am used to talk about in English.
Need specs/part numbers for oxygen sensors - GV 2009 2.0l
Re: Need specs/part numbers for oxygen sensors - GV 2009 2.0
Changed the sensor, but there is still an issue. A mechanic specialised on electronic injection tested the car and thinks the ECM has been damaged by some short-circuit (which makes sense, since a fuse on the oxygen sensor was blown). Now I am looking for a replacement :-(
