Re: New 84' Sj410 Not Starting
Posted: Sun May 17, 2015 1:00 am
I should have mentioned that my carburetor is for an 84' model with added ECU functions on it. Many of these added functions are disconnected & the matching inlets for them on the carb. capped off.
These include the A.B.C.V. ( Air Bleed Control Valve ) & the M.C.V ( Mixture Control Valve. ) PCV valve (Positive Crankcase Vent ) & VTV ( Vaccum Transmitting Valve ) - All of which are only partially functional & the previous owner disconnected in what looks like an attempt to disgnose the no start complex.
I have checked with a multi meter the
WOTS ( Wide Open Throttle Switch ),BVSV ( Bi-metal Vacuum Switching Valve ) and BTS ( Bi-metal thermal valve) all of which have power & appear to be operational.
I've disconnected the ECU as recommened by the shop manual in order of diagnosis yet no change in behaviour is noticed.
