please help with vitara lift and drive shaft
Re: please help with vitara lift and drive shaft
That diff looks way out of angle, looks like one side is sitting higher than the other, by the way you don't need drop brackets unless your going 2 5" or over, not that it hurts using them on a 2" lift but not necessary
Dose this picture help?
- 20150711_125140_resized.jpg (242.05 KiB) Viewed 7814 times
Has somebody fitted uprated springs previously, IE Grand Vitara ??
Looks very much like this http://www.shropshire-suzuki.co.uk/foru ... =13&t=8528
No well I dont think so drive shaft was normal before.any one know the length of the vitara springs.
Fixed the problem with a older drive shaft.thanks for every one's help
- RickUK
- Can I have a tow
That is good news that its all sorted out,but what exactly was causing the problem in the 1st place ?? as that may help other folks as well.
Deceased.
Current wheels.
Current wheels.
All i did was remove the drive shaft with the big can and replace it with the older shorter can drive shaft.it turns fine and looks a beter angle.what's every one els think??
- 20150714_120154_resized.jpg (155.32 KiB) Viewed 7781 times
That's better mate, never thought there would be that much of a angle especially after you used droppers
Glad you sorted it, ill remember this for future reference, I never had this problem when I lifted my old Vitara but when I lift my new one I may well come across this problem!
I think my inner cv on the long can had collapsed.but was fine when off so could just have been that the can was to long so couldn't angle as smoothly.im happy with it no clicking and turns fine.hooe this may help others to come.
