SJ Transfer Case Poly Shifter Sheet Best Place To Buy In UK?
SherwoodNash
Re: SJ Transfer Case Poly Shifter Sheet Best Place To Buy In
Post by SherwoodNash » Wed Jun 29, 2016 12:56 pm
Phillips321 wrote:What plug are you putting back in.... surely not the one you've taken out?
:lol: No! although it is back on temporarily, I already ordered the real McCoy from my Suzuki dealer (£6.36).
I'm trying to keep my van as stock as possible and every main dealer invoice will be good for the provenance folder.
Being steel into Alu, it's going back with copper anti-seize paste :D
Major tip!
Use a 15/16" (23.8mm) 6 Point socket on these 24mm bolt heads, as you can see they are slightly 'sloppy' or even quite rounded, even from new.
zook123
Post by zook123 » Wed Jun 29, 2016 2:12 pm
Can I ask a little favor when you go into the dealership, could you ask how much a drain and fill plug (for the diffs) is for a Jimny? Pretty please?
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by ScottieJ » Wed Jun 29, 2016 3:16 pm
zook123 wrote:Can I ask a little favor when you go into the dealership, could you ask how much a drain and fill plug (for the diffs) is for a Jimny? Pretty please?
What style are the jimny ones, I might have some. You could come check out the mess....I mean workshop
zook123
Post by zook123 » Wed Jun 29, 2016 3:27 pm
PM sent!
SherwoodNash
Post by SherwoodNash » Wed Jun 29, 2016 4:49 pm
If you still want to go down the dealer route.....
From 'Harry' parts advisor at your local Suzuki dealer, Vale Motors, Wincanton.
Filler plug £4.03 + VAT each
Drain plug £5.30 + VAT each (more, as has magnet)
Both would be ordered from Germany and would be available for Friday as they have good stock.
