Steering wheel shake
Eltoon
Re: Steering wheel shake
Post by Eltoon » Wed Oct 05, 2016 5:29 pm
Not done anything about this steering wheel shake yet, mainly as I've done me back in! Just wondering though, if there's only a tiny bit of play in the kingpins, can I just remove shims - assuming there are some in there - and if so, is it just a case of removing the 4 bolts top and bottom and taking them out or do I still need to strip anything down? Sorry for my ignorance! I do have a Haynes somewhere too but buggered if I can find it...
Post by twiss » Fri Oct 07, 2016 12:20 am
Yeah you can remove the shims that easily. Apart from the top ones you will need to remove the brake caliper and possibly the caliper mount too... only 2 or 4 bolts though
Post by ScottieJ » Mon Oct 10, 2016 12:56 pm
twiss wrote:Apart from the top ones you will need to remove the brake caliper and possibly the caliper mount too... only 2 or 4 bolts though
:er: you can remove both top and bottom kingpins without even taking the wheel off
zook123
Post by zook123 » Mon Oct 10, 2016 1:13 pm
Have to take it all off on the Jimny's, bastard of a job!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by ScottieJ » Mon Oct 10, 2016 2:15 pm
zook123 wrote:Have to take it all off on the Jimny's, bastard of a job!
To change kingpin bearings yes...to adjust shims no you don't.
it's an easy job either way ;)
