Page 2 of 4
Re: Spot light wiring
Posted: Fri Aug 05, 2011 10:28 pm
Tramp wrote:
I think only some SJ's are negatively switched, mine is positively like. most cars!
Tramp wrote:Yeah Spanish Sammy and ordinary wiring with negatively switched full beam, I suppose mines. a relatively late one at 92' though
I'm confused Luke
so is your's positively switched or negatively switched
Posted: Fri Aug 05, 2011 10:29 pm
Darrell wrote: My spotlights are wired up just as that diagram and come on with high-beam. It's just past it's MOT like it and nobody commented.
It's only a recent thing as far as I'm aware so i wouldn't be suprised if some testers even know about it
others probably just dont care
Posted: Sat Aug 06, 2011 8:37 am
by Tramp
Argh wires crossed, mine switches the positive leg of the circuit so the circuit has no power until the switch is on, the negative leg goes straight to earth.... and my earth point is on the little struts inside the engine bay, mines not an injection model just a plain old carb'd Sammy
Posted: Sun Aug 07, 2011 10:54 pm
by Darrell
How about this one. Sorry, it was raining, I was a little bored, so blended the 2.
Posted: Mon Aug 08, 2011 6:01 pm
by Rjmaas512
Excuse my really bad work, cba to get photoshop out or the electronic diagram/simulation software out.
This is how mine are wired and it works.
Posted: Mon Aug 08, 2011 6:52 pm
by Darrell
Bet you there not. If you wired them like that the spotlights would come on until you switch the headlights on then they would go off.
If you have switched live then the above headlight circuit is not what you have. your circuit would be like this.
Posted: Mon Aug 08, 2011 8:14 pm
by Rjmaas512
Just went out to have a look to make sure im not talking shit. Pin 86 is connected to ground, 85 to pain beam feed, pin 30 to +ve feed from battery and pin 87 to the spot lights and it works. The spot lights don't come on until I switch main beam on.
I seem to have pin 85 and 86 the other way round to your diagram, but it may be that there is a PD across the coil when main beam is on, resulting in the relay to close is bi-directional, meaning that the current can flow from pin 85 to 86 or visa versa.
This diagram is probably clearer.
http://www.landyzone.co.uk/lz/attachmen ... wiring.jpg" onclick="window.open(this.href);return false;
Posted: Mon Aug 08, 2011 8:39 pm
by Rjmaas512
Ah know what it is, i'm being an idiot. On my SJ you switch the positive to the head lights and the ground is connected to the body. On other peoples SJ you switch the ground, which is why Scotties diagram and Darrell's diagram are correct and why it wouldn't work on my SJ.
Apologies there Darrell my mistake
Posted: Mon Aug 08, 2011 9:34 pm
by Darrell
To be honest I've been messing with SJ's for over 10 years and not come across one yet with switched positive for the headlights but as you know they do exist. Vitara's are also a mixture. Yes pins 85/86 are just a coil so I doesn't matter which way round there wired.
Would be nice to have a wiring diagram for switched positive headlights on a SJ but I've never found one.
No need to apologize, just glad we've sussed it. Cheers - Darrell.
Posted: Mon Aug 08, 2011 10:30 pm
by Rjmaas512
It is probably because mine is LWB and had all the wiring bodged together. I believe I may have sorted all the bodged wiring but I don't want to speak too soon. I will take one piece off and unearth another mess next time I work on the SJ.
Some people really should not be allowed to touch wiring
