Su related problems. Help much appreciated.
scottydouk
Re: Su related problems. Help much appreciated.
Post by scottydouk » Mon Jan 17, 2011 11:32 pm
I have the same problem, was perfect last week, went to use it yesturday then had problems. accelerate heavy or light and car deaccelerates!? deffinatly fueling side, not ignition. carb is brand new and only done around 500miles hassle free. fuel is getting to carb by the plenty, dash pot oil filled and correct needle. hummm.....
any suggestions?
cheers
Post by ScottieJ » Mon Jan 17, 2011 11:55 pm
Hi matey, :welcome: to scuk
Do you know what piston spring is in your SU? Most people find that a yellow one works best on the 1600 ( the tips should be coloured) if its got the wrong spring the piston rises at the wrong speed and give the wrong air:fuel ratio.
Scott
Post by twiss » Tue Jan 18, 2011 3:05 pm
I had all sorts of annoying problems before I put the yellow spring in... 25-75% throttle was a flat spot :shock:
