Another Oil related Question
Smalljeep
Re: Another Oil related Question
Post by Smalljeep » Tue May 24, 2011 11:07 am
when putting it back on does the new gasket need any paste or does it just go on dry
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Smalljeep
Post by Smalljeep » Fri May 27, 2011 1:48 am
the oil leak then, it was just the rocker gasket, all fixed now.
Post by ScottieJ » Fri May 27, 2011 9:14 am
Smalljeep wrote:the oil leak then, it was just the rocker gasket, all fixed now.
Good to hear :thumbup: kinda useful that I found those O-rings anyway as I need one for mine :lol:
Smalljeep
Post by Smalljeep » Sat May 28, 2011 11:39 pm
theres stiill a bit of a weep of oil
Smalljeep
Post by Smalljeep » Sun May 29, 2011 6:48 pm
does this include an inlet manifold and fuel pump gasket, can anyone tell from the pics?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _500wt_922" onclick="window.open(this.href);return false;
im going to pull off the inlet manifold and fuel pump, change the pump over to the other one i have, and put the new gaskets on, failing that i dont know.
Its too high for the sump and not the filter, round the dizzy seems clean, the fuel pump is a bit oily though especially round that hole on the side of it.
Post by ScottieJ » Sun May 29, 2011 8:35 pm
There's no oilways around the inlet manifold so you don't need to take that off, you can remove the fuel pump without removing the inlet manifold and no that kit doesn't include a fuel pump gasket. From a main dealer they are £7.17 before vat each and you need 2 if you have the plastic spacer in between the fuel pump and head :shock:
Smalljeep
Post by Smalljeep » Sun May 29, 2011 11:14 pm
about £15 ish then i suppose, ill need to become acquainted to my suzuki dealer then
Smalljeep
Post by twiss » Mon May 30, 2011 9:57 pm
Unfortunately there are some things that you really have to get from suzuki... speedo cables seem to be another one!
Smalljeep
Post by Smalljeep » Tue May 31, 2011 1:12 pm
same as peugeot dealers then, although with them its usually the diagnostics machine for electrical problems. Although i bought one there is still some parts only the dealers have.
As for the gearbox oil
i took the lever out and filled it through here, i also loosened that bolt at the side when doing it, is that the place where you are supposed to fill it, its about 4 inches back and up from the drain plug?
