Changed the fuel pump but theres something wrong
Smalljeep
Re: Changed the fuel pump but theres something wrong
Post by Smalljeep » Sun Jun 05, 2011 6:37 pm
sorry
all sorted now
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Henry
Post by Henry » Sun Jun 05, 2011 7:04 pm
Still not working :poke:
Smalljeep
Post by Smalljeep » Sun Jun 05, 2011 7:12 pm
http://www.youtube.com/watch?v=6uO0htE9R8w" onclick="window.open(this.href);return false;
Click Here for Youtube Video
its set as public now
Henry
Post by Henry » Sun Jun 05, 2011 8:47 pm
Have you checked to see if your pulling in air.
To me sounds like the new pump diahpram is buggered. Stick the old one back on
Post by ROBBIE » Sun Jun 05, 2011 8:56 pm
is all the pluming still where it should be on the carb?
Smalljeep
Post by Smalljeep » Sun Jun 05, 2011 9:00 pm
all the plumbing is untouched, i changed back to the old pump, and then did the video.
Post by ScottieJ » Sun Jun 05, 2011 10:14 pm
Bit of a long shot but you haven't somehow broken a wire on or dissconnected the fuel stop solenoid during the swap? I had a similar issue and all it was was the earth wire snapped
Mine has a green connection but some are brown. Follow the wires to wherever they go on the otherside of the connection, one wire should go to an ignition live and the other to an earth somewhere.
Also might be worth checking the fuel filter for blockages? Or even Stripping the carb to clean the jets?, its not that difficult, i'll try and find a write up, I used to jag some pics of my own somewhere :er:
Smalljeep
Post by Smalljeep » Mon Jun 06, 2011 10:01 am
the green plug on the thermostat ill have a check to see if its been knocked, but the engine did run smooth since the engine was put into the anus.
As for rebuilding the carb isnt that suzuki carb an absolute pig to work at, all wee small starheads that just run the heads off when you try and open them, but ill give it a go anyhow.
Smalljeep
Post by Smalljeep » Tue Jun 07, 2011 12:37 am
hi
i noticed that a earth wire was loose, reconnected it and hey presto it ran nice.
But the problem is still about these 2 fuel pumps they are obviously both crap, its a waste of a good gasket swapping them over all the time, the one in at the moment is excreting a black fluid most likely oil. My mechanic had a look at them and said they are knackered.
Can i blank it off and put in an electric fuel pump, is the plumbing complicated most concerned about the return pipe as electric pumps seem only to have an in and an out pipe nothing for return, and do they work at the right speed?
Smalljeep
Post by Smalljeep » Tue Jun 07, 2011 11:37 am
i had a look on ebay, this is a reasonably priced fuel pump, can i fit this to the suzuki, how many people have done this?
