Differentials: Setting up and servicing etc.
Cyprus Geoff
Re: Differentials: Setting up and servicing etc.
Post by Cyprus Geoff » Wed Jul 18, 2012 3:10 pm
Hi M!! You get everywhere!! :lol: :doublethumbs:
Post by Jordi » Sat Jul 13, 2013 8:51 pm
Maybe i'm being special. But can someone point out to me where this whole thing mentions the seal?
Post by ScottieJ » Sat Jul 13, 2013 9:44 pm
Bevel pinion preload setting page 16-9
Post by Jordi » Sat Jul 13, 2013 10:14 pm
Is that bearing preload still accurate enough to measure it whilst the diff is in the Zuk with the additional force required to turn the shafts/wheels?
Or should the diff be removed to set it up properly?
Post by ScottieJ » Sat Jul 13, 2013 10:19 pm
It's prob best to pull the shafts then you can at least measure the starting torque before you take it apart. You could always by a solid crush collar and follow this guide
http://www.rsmfg.co.uk/page17.html
Post by dan_2k_uk » Sat Aug 16, 2014 4:36 pm
Differential Ring and Pinion Gear Setup: http://youtu.be/dAqAqODmcj4
Really really good video on this subject I just found as I am building some vit ring and pinions ito SJ diff's anddont like reading.
Perry
Post by Perry » Thu Feb 26, 2015 11:44 am
Please help. I am in a country with no special tools, I have removed the pinion, I do not have a bearing splitter and want to change the bearing (knackered) have you any ideas how I can remove it.
Thanks in advance
Chris2017
Post by Chris2017 » Mon Aug 28, 2017 10:15 am
Hi,
I am new to the world of 4x4s and relative beginner at mechanics.
I have an sj413 samurai and I have carried out a spoa conversion... I bought a set of second hand axles which were already converted. Unfortunately when I filled the diff up with oil the oil poured out in two places. The first was where the prop shaft connects - I believe this is the pinion seal. However, the second place was behind where you attach the wheel... The rear axle has been converted to discs. Please can someone advise me of what I need to replace and the part/parts I need?
Thank you in advance for any help or suggestions.
Regards
Chris
Tommy67
Post by Tommy67 » Sat Nov 07, 2020 10:25 pm
Hello
Its my 1st post. Just wondered if the gearbox on the sj413 is exactly the same as the jimny 2001. Also is the front/rear diffs interchangeable between the sj & jimny. Just trying to establish what sj parts i can use if the need arises. Many thanks
