Sj running hot
Re: Sj running hot
Post by twiss » Wed Aug 03, 2011 11:55 am
Also, I just noticed you've said you are using the heater to cool the engine...
Are you sure your rad is clean? Even if it's 25% blocked with mud, the 1.3 rad can suffer a bit with the 1.6 engine
Re: Sj running hot
Post by Edweird » Wed Aug 03, 2011 4:16 pm
Cleaning your rad can work wonders and cause disasters. You would not believe the amount of shit that was stuck on the rad in my mum's discovery. Half a tree, a dead mouse and a hell of a lot of compost from the rotting vegetation. However, when we got the rad out and hoovered it, most of the thin elements were so rotten they went up the Dyson. By the time we were done it looked like someone had shot at it.
Re: Sj running hot
Post by twiss » Wed Aug 03, 2011 4:41 pm
See I clean mine after every off road day... it means the mud doesn't get a chance to rot away the fins and it keeps the radiator nice :)
I just take the whole thing off and leave it immersed in water for an hour... then gently hose it off
DO NOT USE A PRESSURE WASHER ON IT
ferris
Re: Sj running hot
Post by ferris » Wed Aug 03, 2011 7:01 pm
When you said clean the rad, i thought you ment the inside :hahaha: . So i drained the system and put the hose pipe on fulll blast in the top :hahaha: . Now looking at the out side of it, it is packed full of mud. So i'l have a go at cleaning that out tomorrow.
I also checked the water pump pully. That seammed to move nice and easy, and i also put a new fan belt on.
mayhemmiller
Re: Sj running hot
Post by mayhemmiller » Wed Aug 03, 2011 11:06 pm
flushing the inside through woun't do any harm did you have the bottom hose off when you had the hose in top
awaiting the next adventure
:mayhemmiller:
ferris
Re: Sj running hot
Post by ferris » Thu Aug 04, 2011 6:50 pm
No, i just had the tap on the bottom open.
