LEAKS....
Re: LEAKS....
Post by twiss » Tue Sep 06, 2011 10:53 pm
I don't think you even need to take the wheel or the caliper off to change the pads and felt.
Easiest with a flexy head 12mm spanner!
Russ24
Re: LEAKS....
Post by Russ24 » Thu Sep 08, 2011 9:10 pm
im doing the kingpin bearins aswell so will need to take wheels off i feel.
and the drive shaft oil seals.
:russ:
Re: LEAKS....
Post by twiss » Fri Sep 09, 2011 9:19 am
Yeah you will need to take the wheels and the calipers off to get to the top kingpin
Re: LEAKS....
Post by ScottieJ » Fri Sep 09, 2011 9:32 am
And to take off the knuckle, I don't bother taking the hub off, just undo the 4 bolts behind the disc that hold the stub axle on, saves some time that way.
Russ24
Re: LEAKS....
Post by Russ24 » Fri Sep 09, 2011 10:53 pm
ScottieJ wrote:And to take off the knuckle, I don't bother taking the hub off, just undo the 4 bolts behind the disc that hold the stub axle on, saves some time that way.
but if im doing the drive shaft oil seals, king pin bearings and the felts n rubbers.... and removing the stupid brake disc housing. then its worth taking it all apart.
:russ:
Re: LEAKS....
Post by ScottieJ » Sat Sep 10, 2011 12:28 am
Those 4 bolts that hold the stub axle on hold the disc cover on, i mean you can get to them without bothering to remove the hub and wheel bearings from the stub axle as a lot of people strip the whole assembly down to remove the stub axle when you don't need to. Don't forget to remove the circlip from the end of the halfshaft first though ;)
Russ24
Re: LEAKS....
Post by Russ24 » Wed Sep 14, 2011 1:32 pm
ScottieJ wrote:Those 4 bolts that hold the stub axle on hold the disc cover on, i mean you can get to them without bothering to remove the hub and wheel bearings from the stub axle as a lot of people strip the whole assembly down to remove the stub axle when you don't need to. Don't forget to remove the circlip from the end of the halfshaft first though ;)
and so. it looks asif i can crack on. :D
thank you all that have contributed
:russ:
Re: LEAKS....
Post by ScottieJ » Wed Sep 14, 2011 1:36 pm
go on then get on with it :middelfangers:
Re: LEAKS....
Post by twiss » Wed Sep 14, 2011 1:38 pm
Yeah russ get on with it! and GOOD LUCK CHAP!
Re: LEAKS....
Post by ScottieJ » Wed Sep 14, 2011 1:41 pm
Twiss will always come over and help if you get stuck :mrgreen:
not that i'm sure thats a good thing ;) :thefinger:
:hahaha:
