new vitara project
Re: new vitara project
Not usually a fan of vits, but that is impressive
. Looks the nuts man
The tyres won't self clean properly when going forwards when fitted in that direction. They will perform better in the mud if you turn them aroundvitara_mad wrote:your not the first 1 to say that about the tyres & even i thought they looked wrong but ive put them on with the direction arrow facing the correct wayScottieJ wrote:Looks awesome mateyI like that front bumper.
One thing though... your tyres are on the wrong way aroundif I remember it was those ones that had the arrow moulded on them facing the wrong way
do you think i should swap them around ???
If you look at interco super swampers, the tyres those ones copied you'll see that they are supposed to be fitted the other way
thanks scottie i think i will do that
things have moved on a bit sinse i last updated this as its been a while
fitted twin transfer box
- CIMG0652.JPG (247.96 KiB) Viewed 8313 times
- CIMG0653.JPG (211.34 KiB) Viewed 8313 times
- CIMG0655.JPG (260.28 KiB) Viewed 8313 times
- CIMG0656.JPG (232.07 KiB) Viewed 8313 times
made a rear disc conversion although its not longer fitted as ive swapped to landy axles
- CIMG0556.JPG (235.07 KiB) Viewed 8310 times
- CIMG0559.JPG (231.36 KiB) Viewed 8310 times
- CIMG0558.JPG (305.82 KiB) Viewed 8310 times
did the widening mod on front end although i did it slightly differant to others have by moving front mounts out as well , did stubby shaft conversion & modded the wishbones to relocate the spring seats so springs sit straight
- CIMG0586.JPG (221.21 KiB) Viewed 8306 times
- CIMG0588.JPG (235.22 KiB) Viewed 8306 times
- CIMG0596.JPG (202.55 KiB) Viewed 8306 times
- CIMG0590.JPG (249.04 KiB) Viewed 8306 times
its had quite alot of abuse & done well but now its fitted with disco 300tdi axles
Nice work! You're gonna love the twin transfer boxes!
You got any other pics of the set up before its fitted?
i already do love it its been out & abused a few times sinse its been fittedScottieJ wrote:Nice work! You're gonna love the twin transfer boxes!
i will have a look see if i got any pics of the box before it was fitted its not same as yours though not built by rockwatt
