help please
- mayhemmiller
- Can I have a tow
Re: help please
was checked by the breakdown guy he used a neat little trick of taking of the fuel line off the pump then used and airline and a rag in the filler cap and fuel came out of hose
awaiting the next adventure
![:mayhemmiller: :mayhemmiller:](./images/smilies/mayhemmiller.png)
Re: help please
Cool. Well thats a step in the right direction. Ive fitted an aftermarket electic pump on mine. A low pressure facet pump as my mechanical one broke. Never looked back. Hope u get it sorted pal
LJ80Q
Re: help please
I would recommend a facet pump as well, they're only £30 ![:D :D](./images/smilies/icon_biggrin.gif)
- Russ24
- Can I have a tow
Re: help please
twiss wrote:I would recommend a facet pump as well, they're only £30
hell yeah. and the electric clicky noise reminds you its working :p
![Image](http://farm9.staticflickr.com/8056/8438645884_b2df455aac_z.jpg)
![russ's sj side :russ:](./images/smilies/russ-gif.gif)
- mayhemmiller
- Can I have a tow
Re: help please
well finally got some time this evening to try some tinkering on the truck turns out the fuel pump is fine i tested it by put a smaller piece of fuel pipe on the inlet nozzle and the other end of the pipe in a jar of fuel turned it over started beautifully first turn and sucked down the jar of fuel just fine and was running fine
Re: help please
First of all i would check the power supply to the solenoid/fuel cut off valve on the carb if one is fitted. Put a +ve feed from battery straight to the solenoid wire and just touch it on and off and you should hear it click when you touch wire if its working. Then i would check the carb where the fuel line goes in. Some have a gauze there that blocks sometimes. Have you tried staring it since?
LJ80Q
- mayhemmiller
- Can I have a tow
Re: help please
yeah like i said had it running
Re: help please
Glad you got it sorted. I just put the above in just in case its intermittent and cuts out on you again.
LJ80Q
Re: help please
I know the breakdown guy used compressed air to push fuel to the pump so this it considered clear, but then why does it run from a jar of fuel
I wouldn't expect the pump to create much suction so maybe there is a restriction in the fuel line, is the filter on the chassis ok. If it hasn't been changed for some time it may be worth bunging a new one on, you don't need to buy a genuine suzuki filter as lots of brands do copies for about a fiver.
![scratch :er:](./images/smilies/icon_scratch.png)
- mayhemmiller
- Can I have a tow
Re: help please
gonna check it latter it has a new one on it
