new here
Re: new here
i need the whole back shoes and fitting kit because i have nothing in my rear drums if any 1 can point me in the right direction and a front drivers suspention mount cheers many thanks
Re: new here
What do you mean by front suspension mount.
Spring plate, spring bushes, shock bushes?
Think the rear shoes are different between spanish/jap. Whats the first 3 letters of your vin no?
Re: new here
It looks like a spanish 413 samurai to me...
The pics are a bit blurry but I think I can see the springs are out further than the chassis, and there doesn't seem to be 2 reverse lights on the back
Re: new here
I was trying to do a vrm lookup lastnight but couldnt figure the reg no out
Re: new here
H979 XGY
It's a 1990 1298cc which makes it a Spanish Samurai Sport I believe!
Not been taxed since Feb 2003...
One thing I would watch out for if you want to put it back on the road...
It's registered as being white, although it clearly isnt any more
Re: new here
thank you every 1 an i no bout it been white thanks i mean my shocker mount on the chassie
and the reg is h973xgy an it should have been last taxt in dec 2010 running out in 2011
and it is the spanish model im not shore but i think its 1324cc
ill take as much advice as possible and help because im new to the suzuki im only trying to get it on road for a bit then next year im on with a full restoration many thanks every 1
Re: new here
There you go. Pretty much tried every guess apart from that.
- capture_03.png (51.36 KiB) Viewed 5309 times
Re: new here
Can see where Twiss got 1298cc from tho.
Heres H979
Heres H979
- capture_04.png (49.5 KiB) Viewed 5306 times
