Stalling in tickover
charger
Re: Stalling in tickover
Post by charger » Mon Feb 20, 2012 12:35 pm
How do you alter the mix where s that screw,
I have also just noticed there should be a pip that goes from the right hand side of the engine over the top in the to cold air feed mine is missing.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Post by ScottieJ » Mon Feb 20, 2012 12:41 pm
ScottieJ wrote:have you checked the wiring to the fuel stop solenoid?
Honestly I would check this first, before continuing, if the fuel stop solenoid is restricting fuel flow (they dont completely stop it when there is now power feed) then you wont be able to set the fuel mixture as the carb wont be getting enough fuel!
charger
Post by charger » Mon Feb 20, 2012 12:47 pm
I will check that first any pointers to where it is?
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Post by ScottieJ » Mon Feb 20, 2012 1:17 pm
Trace all the wires and check that you have power witht he ignition on and that the earth hasn't broken.
a few other pics to help you
charger
Post by charger » Mon Feb 20, 2012 8:23 pm
Thanks for that will be having a crack 2 moz
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
charger
Post by charger » Sun Feb 26, 2012 9:50 pm
It no longer cuts out but I had to set the idle to 3000rmp to stop the problem so not a great fix. I had the electrics checked out with one of them hand held devices & the problem isn't there.
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
