Vitara build
Re: Vitara build
Can anyone teld me if I have to change any of the engine mounts. Thanks
Re: Vitara build
Use both 1300 mounts. The passenger one lines up ok with the spreader plate fitted.
The drivers side wants the spreader removing and a hole drilling on the chassis mount for the single bolt from the rubber block.
Dan
Dan
Re: Vitara build
Sorry to sound think but I'm new to this. Whats the spreader plate
Re: Vitara build
Theres a plate shaped like this on the mounts _.--._
The two lower parts bolt to the chassis mount and the raised part has a stud through it from the rubber mounting.
Dan
Dan
Re: Vitara build
Ok I'm with u now thanks for help. Wat did you do about your fuel pump
