Nope
Never seen a kit for the 410. Guess it's not common enough.
Just think of how many samurai's there are in the USA.
Engine Hoses
Re: Engine Hoses
- 410.gif (43.08 KiB) Viewed 13731 times
- lazy rambler
- Can I have a tow
Re: Engine Hoses
The hoses arrived today, look good on first inspection but I'll let you know how good when I come to fit them.
- DSC01242.JPG (4.06 MiB) Viewed 13705 times
- lazy rambler
- Can I have a tow
Re: Engine Hoses
Just compared them to the standard ones that I'm replacing. The bore size is spot on, maybe a little tight, but some of the pipe may be a bugger to fit as the shape isn't quite right, some worse than others.
- Number 13 on above.
- DSC01243.JPG (358.68 KiB) Viewed 13697 times
- Number 12 on above
- DSC01244.JPG (301.24 KiB) Viewed 13697 times
- Number 11 on above
- DSC01245.JPG (4 MiB) Viewed 13697 times
- Number 17 on above
- DSC01246.JPG (383.44 KiB) Viewed 13697 times
- Number 20 on above
- DSC01247.JPG (310.36 KiB) Viewed 13697 times
- Number 19 on above
- DSC01248.JPG (358.54 KiB) Viewed 13697 times
- 413 hoses.jpg (84.72 KiB) Viewed 13697 times
Re: Engine Hoses
Looks promising
My lower hose is equal unlike the one that was fitted to yours. IE: like the one supplied.
My heater out hose is like the one supplied. Yours looks like a piece of universal hose.
The others hoses match
- bottom hose.jpg (104.94 KiB) Viewed 13690 times
- Heater out hose.jpg (214.49 KiB) Viewed 13690 times
Re: Engine Hoses
Spotted one potential problem. As these kits are aimed at the American market that is what there made for. Only thing is hose number 19 is different on a right hand drive vehicle. In your photo they look to match quite well, but mine has a tight 90 degree bend just under the heater valve like shown in this diagram.
- heater hose differences.jpg (191.81 KiB) Viewed 13613 times
- lazy rambler
- Can I have a tow
Re: Engine Hoses
19 is on & in place it's a little big lenght wise by a good fit, I'll put a pic up when I'm home.
- lazy rambler
- Can I have a tow
Re: Engine Hoses
The one I most concerned about is hose 20. As I'm fitting it to a 1.6 the exit for the water rail (or whatever it's called) isn't on the back, it's on the side
Anyway this is 19 in position.
- DSC01254.JPG (3.31 MiB) Viewed 13540 times
- DSC01255.JPG (3.28 MiB) Viewed 13540 times
Re: Engine Hoses
I see your heater valve is already fitted at an angle which helped the hose fit
I see what you mean about the water rail being different on the 1600.
- 1600 hoses.gif (50.28 KiB) Viewed 13524 times
