Joe's lj
juncopartner
Re: Wanted
Post by juncopartner » Thu Nov 15, 2012 12:51 pm
Got loads of SJ 410, 413(early type, think they are lower geared and 4 pinion, I think later ones are 2 pinion but not sure) and LJ's diffs as well. Like I said I have a mountain of them. Should have a spare door or two!!!! I'll have a look at the weekend check how many and condition.
Re: Wanted
Post by ScottieJ » Thu Nov 15, 2012 1:03 pm
ah cool! I would be after 2 rear of the early 413 diffs as they are lower geared than samurai diffs as you say.
awesome, if you do have some spare that would be great, my dads doors are rusted through!
juncopartner
Re: Wanted
Post by juncopartner » Thu Nov 15, 2012 1:12 pm
I'll try to have a look in lock up's this weekend, they are 65 miles away from where I live!!! Moved house but still have the lock ups back up there with the LJ's and Morris Minor in them. My garage at home is full of Lambrettas and Vespas!!!
Re: Wanted
Post by ScottieJ » Thu Nov 15, 2012 1:25 pm
there's no rush at all! I've just bought a lwb so prob wouldn't want them for a while yet.
Bray
Re: Wanted
Post by Bray » Thu Nov 15, 2012 10:44 pm
Thanks juncopartner,
I am going to strip the doors down to see what I really need then I will let you know what I need.
As for the front diff I was thinking off trying to adjust it to reduce the back lash if this is possible.
I've just got a rocklobster tbox as the one fitted was A sj413 with a fair amount of play from in put to out put also front bearing and seal nackered
I'm getting there with the little beast and will post so picks soon as I get some time to get stuck in
Re: Wanted
Post by Darrell » Thu Nov 15, 2012 11:31 pm
Can't help with any spares, but --
LJ80 window winder.jpg (118.7 KiB) Viewed 9941 times
Bray
Joes lj
Post by Bray » Fri Nov 16, 2012 8:48 pm
That's helpful but I'm trying to work out what part 10 is and I guess 16 is the vertical runner.
I took the door cards off and found only passenger regulator in place and both windows held in place with wood screwed along the bottom, so I think I need part 10,16, regulator for drivers side and the runner part that's on the bottom off the window plus some rubber seals.
Got the rocklobster tbox in and has sorted the horrendous whining just need to have a look at the front diff as when in 4l there is way too much slack/backlash and does not sound good, can the backlash be adjusted on lj diff?
Bray
Re: Joe's lj
Post by Bray » Mon Nov 26, 2012 9:27 pm
wilst installing my new rocklobster i Used this
to make this
so thats fixed the seriously loud whine and given me nice low gearing.
any way still after window parts if any ones got them
OllieSJ
Re: Joe's lj
Post by OllieSJ » Thu Sep 05, 2013 6:39 pm
Hi what engines in this thanks
Bray
Re: Joe's lj
Post by Bray » Fri Sep 06, 2013 12:28 am
1.3 sj engine
