Page 2 of 2
Re: 1600 16v on carb?
Posted: Fri Nov 23, 2012 3:44 pm
Yeah but with an SU you can just take it off and clean it all out in half an hour ;)
Posted: Fri Nov 23, 2012 4:15 pm
As long as you put the ECU in a sensible place up high then they are just as good in deep water as any other petrol engine!
If I was to fit a 16V I would run the MPFI without question!
Posted: Tue Nov 27, 2012 9:48 am
Yeah maybe me too under usual circumstances, but Tims 16v SU engine was too much to resist! :)
Posted: Wed Apr 24, 2013 4:42 pm
by SJ Greg
Twists are the 16 v inlets the same as 8v?
Posted: Wed Jul 17, 2013 6:15 pm
by Rhinoman
No they aren't.
Any pics of the distributor conversion?
Posted: Thu Jul 18, 2013 9:12 am
Hi,
I havent got that many pics but here we go....
Basically Tim has attached the majority of a samurai dizzy onto the base of the 16v vitara dizzy...
He's also had to put the distributor shaft on the other side of the camshaft gear so it spins the dizzy the right way round
Posted: Thu Jul 18, 2013 4:12 pm
Just a small note. SU carbs are brilliant and work very well in most conditions and weird angles.
Not so good if they have no dash pot screws in though are they Twiss?
Posted: Fri Jul 19, 2013 9:56 am
It still sort of worked!!! I'm surprised I got as far as I did with no screws!
Posted: Sat Aug 10, 2013 2:21 am
by gell
Hi twiss
can you explain what was done to adapt the distributor housing to the 16 valve head.
Many thanks
gell
