I can remove the pipe on top of it and press against a spring with a small screwdriver.
Does this confirm that it's working or could there be a blockage behind it maybe?
Pissing oil out big time after new rocker seal
Re: Pissing oil out big time after new rocker seal
You could always stick your mouth on it and suck and blow it shouldn't let you suck but should let you blow
Could be blocked behind it. Need to whip it out and check it rattles and air can move through it.
Dan
Dan
Don't fancy sucking my engine off tbh. Lol
Il try and remove the valve at work.
