What model carb is this?
Re: What model carb is this?
Post by dan_2k_uk » Fri Jan 11, 2013 7:20 pm
8.20 am and you're working on your carb! :suzuki:
kiwizook
Post by kiwizook » Fri Jan 11, 2013 7:24 pm
there is a little tab there that holds it in that angle. if you look carefully, you can see it in the photo.
Is there any fuel going past this bolt holding the float chamber on, or is it just a mounting point? because if it is just a mounting point, i could just grind the little tab of, and bolt it on straight. what do you think?
Post by dan_2k_uk » Fri Jan 11, 2013 7:33 pm
To be honest..... not a clue!
kiwizook
Post by kiwizook » Fri Jan 11, 2013 7:45 pm
We'll wait for some other knowledgeable people.
about the working on my carb at 8.20 am, i started work at 4.00 am and got home at 7.00 am so yea, got time now, work starts again at 2.00pm :D
Post by dan_2k_uk » Fri Jan 11, 2013 7:53 pm
Sounds the same as my callout week at work!
kiwizook
Post by kiwizook » Fri Jan 11, 2013 8:01 pm
it's dairy farming. luckily it's only a weekend every fortnight, and only one more weekend to go before i quit
Post by dan_2k_uk » Fri Jan 11, 2013 8:03 pm
bit different to sewage pumping then! :D
kiwizook
Post by kiwizook » Fri Jan 11, 2013 8:04 pm
not really, there's a lot of cows**t in the milking shed, i'll tell you
Post by Jordi » Fri Jan 11, 2013 9:33 pm
The last few posts there both amused and confused me.
I do like the keep as far away from both cowsh*t and sewage much as i can if that counts for anything.
kiwizook
Post by kiwizook » Fri Jan 11, 2013 10:29 pm
Jordi wrote:The last few posts there both amused and confused me.
Fair enough mate, I want to as well in the future :brows:
Anyways, anyone knows anything about the float chamber question posted earlier? I would love to sort that carb out
govert
