Wheel hub empty
fozzyx123
Re: Wheel hub empty
Post by fozzyx123 » Tue Feb 19, 2013 11:05 am
thats great... many thanks
Re: Wheel hub empty
Post by ScottieJ » Tue Feb 19, 2013 11:24 am
Jordi wrote:http://item.mobileweb.ebay.co.uk/viewit ... 0847481023
Take look. Fairly sure that's the one. You'll also need brake cylinder.
Yup that looks correct! Think those bits are the same on all of them.
fozzyx123
Re: Wheel hub empty
Post by fozzyx123 » Tue Feb 19, 2013 12:59 pm
I'm getting confused on brake cylinders... ive seen new ones from as little a £2 varying up to £36.....
Re: Wheel hub empty
Post by Jordi » Tue Feb 19, 2013 1:28 pm
Im going off memory here.
http://item.mobileweb.ebay.co.uk/viewit ... 1070916221
If that is the right picture it looks like the right one. New rear brake cylinders will be about £12 to £15 each.
Re: Wheel hub empty
Post by ScottieJ » Tue Feb 19, 2013 1:48 pm
You need to make sure you get the correct cylinders, The samurai ones might be a different size to 410 ones and I'm pretty sure the jap and spanish ones are different lengths as well.
I'm pretty sure early 410s have different cylinders as well; being a D reg yours is a late one.
Also remember that they are sided.
Is your sj410 jap or spanish?
VIN number starts
JSA for jap
or VSE for spanish
fozzyx123
Re: Wheel hub empty
Post by fozzyx123 » Tue Feb 19, 2013 2:51 pm
how do i tell? i have no log book yet
Re: Wheel hub empty
Post by ScottieJ » Tue Feb 19, 2013 2:59 pm
The vin plate is just inside the drivers footwell near the speaker hole, and chassis number is stamped on the chassis under the driver side wheel arch on the chassis leg about 6" ish in Frnt of the shock mount
Re: Wheel hub empty
Post by twiss » Tue Feb 19, 2013 4:34 pm
Mines in my glovebox, sort of chopped it off to do some welding and forgot to rivet it back on ;)
MOT man wasnt massively happy about it!
Re: Wheel hub empty
Post by andyrew » Tue Feb 19, 2013 6:20 pm
In you intro thread. You said it's purely off road. Is it worth doing the rear brakes?
Re: Wheel hub empty
Post by Jordi » Tue Feb 19, 2013 6:29 pm
It has absolutely no rear brakes andy. I'd want something. Even off road.
