Starting
Re: Starting
Yeah well it's been stood for a bit ,what they like to strip down ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
Easy enough
If your a little unsure you could always just clean the solenoid up and leave the rest.
Not sure if you could do that with the starter still in place
Re: Starting
Thanks bud I,ll get it off and have a go
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Starting
If you get the starter off and undo the link wire from the solenoid (magnetic switch) to main body and undo the 2 screws holding the solenoid on, the solenoid body will pull off. Then you can lift the solenoid plunger off the lever. This plunger should move freely inside the solenoid body and is what can rust up.
Also make sure the pinion and clutch move freely on the shaft.
Hopefully this will fix it, but it's worth a try before spending on a new one
- sj 413 starter motor.jpg (256.99 KiB) Viewed 3861 times
Re: Starting
Awesome will let u know how it goes
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
